Mar 27 2007, 06:22 PM
Post
#1
Newbie ![]() Group: Members Posts: 6 Joined: 12-December 07 Member No.: 354 |
http://home.comcast.net/~sihing_steve/Vacu...Inches_iges.TAP
When working witht the above file in NC Tuner, the drill bit displayed or being used by NC Tuner is incorrect in size. When attempting to change the bit size we receive a Windows handle error 1400, and cannot get the sub menu to display correctly so that we may change the bit size. Any ideas? Regards, Steve |
Mar 27 2007, 09:28 PM
Post
#2
![]() Advanced Member ![]() ![]() ![]() Group: Administrators Posts: 647 Joined: 12-December 07 From: United Kingdom Member No.: 4 |
Hi Steve, not sure on that one, I don't use NCTuner much.
It's possibly a postprocessor error, so we would need this to be able to check it. Can you make it available for download and I'll take a look for you. Dave |
Mar 28 2007, 03:35 PM
Post
#3
Hi Dave, thanks for your response.
Is the file in the link I provided not sufficient? Regards Steve |
Mar 29 2007, 03:25 PM
Post
#4
Hi Steve, in order to try and duplicate the fault, it would be useful to have the postprocessor that's being used with the G-code file (supplied) as the problem may be related to this.
Do you know what version and build of NCTuner that you are running? Dave |
Apr 2 2007, 07:46 PM
Post
#5
Dave,
We are using the most recent NCTuner available at SprutCAM. The post processor is the PCNC1100.spp, do you need this file? Regards..... |
Apr 5 2007, 09:13 AM
Post
#6
Hi Steve, I believe that Sprut have found the cause of this problem and are now getting this sorted for you?
Let me know if you haven't heard back from them. Dave |
| Lo-Fi Version | Time is now: 10th September 2010 - 09:52 AM |
