> Auto Deburring
pbachert
post Jul 2 2009, 04:44 PM
Member
Anyone know how to turn off automatic deburring in SprutCam? It machines in areas where I do not wan't it to go thinking it's removing sharp edges and sometimes it's not. Short of manually changing the code has anyone else delt with this issue? Pete Bachert
post Jul 2 2009, 10:09 PM
Hi Pete, I'm not sure which function you are referring to as Automatic deburring.........can you give a bit more info, or, provide an example project which shows the problem?
I'm sure we can help to solve the problem with a bit more info.
pbachert
post Jul 6 2009, 01:20 PM
Member
QUOTE (Sprut_UK @ Jul 2 2009, 06:09 PM) *
Dave, Sprutcam creates a toolpath that goes around the corner instead of straight off the part like it's trying to remove the sharp edges left by the cutter. It does this on waterline and flat land finishing operations. I would like the path to go straight off the part, not around the backside of the part I'm making. For some reason the forum won't let me upload any of my project files I can use an example. Do you have an e-mail address I can send a file to? Pete
post Jul 14 2009, 10:20 AM
Hi Pete, I apologise for the delay in responding, but I have been on vacation.
You can send your project to daveATsprut.co.uk just replace AT with the appropriate symbol........
LRG
post Dec 27 2012, 01:33 PM
Newbie
I am having the same issue. I want to side mill a end of a block to clean up extra stock, to bring it to size. The block is square but the tool path is wanting to wrap around the edges of the block. I'd rather see a straight A to B path and retract, rather then having the lead in/out arcs. Am i using a wrong operation?
post Dec 28 2012, 04:02 PM
Hi LRG, and welcome to the SprutCAM forum.
There is a function for solving this problem which can be found under 'Trimming', it's called 'Trim rolls'.
When machining simple 2D parts like this you can very often get a lot better control over the machining process by using 2D strategies.
In the attached modified version of your project I have used '2D Contouring' to machine the part. I haven't applied any speeds / feeds etc.
I hope this gives you some idea's.
Nelly_SC
post Jan 20 2017, 02:14 PM
Post #7
Newbie
I know that's the old topic, but here's the video according to it.
https://youtu.be/bssbgMG0g10
Off-line programming for deburring parts in SprutCAM Robot for FANUC M710 robot.
https://youtu.be/blHfC-QTL6M
Lo-Fi Version Time is now: 22nd January 2019 - 02:36 AM
