> Can't get toolhead.osd file to appear in simulation
post Aug 8 2014, 04:05 AM
I've done this successfully before....but that was last November, and I can't get it right now. I'm trying to change the toolhead on my Kuka robot in SprutCAM, but when I bring in the Inventor file, select it and export it as an OSD file, it refuses to re-appear in SprutCAM at the end of the complete robot. There's some silly, small step I don't remember. I've attached an image showing my attempt to do this...what on Earth am I doing wrong here?
Attached File  toolhead_OSD_export_problem.JPG ( 143.97K ) Number of downloads: 10
post Aug 9 2014, 06:11 AM
It isn't very clear from your screengrab, are you putting the 'ToolHead.osd' file into the correct folder, for example 'C:\ProgramData\Sprut Technology\SprutCAM\Version 8\Machines\CustomSchemas'? Does the existing Robot configuration already use an end effector called 'ToolHead.osd'?
Some robot configurations can add an 'end effector' model from within SprutCAM. You might need to move the end effector model to align it with the robot.
Please see the attached image which might give you some idea's?
post Aug 10 2014, 09:00 PM
I figured it out....sure enough, it was a very specific setting. The only way I got it to work was export the Inventor part as an IGES file, and then I I had to set it to export as "Solid" instead of "Surface" in Inventor rolleyes.gif
Lo-Fi Version Time is now: 19th July 2019 - 02:10 AM
