> Creating a new coordinate system
post May 25 2005, 04:50 AM
Hi All, here is a video tutorial which shows how to create a new Local Coordinate System in SprutCAM version 4. This is particularly useful if you need to set a machining datum, but cannot set it by using the normal technique (Transform - Locate zero). An example of this would be needing to use a hole or pocket centre as a datum.
Anyway, the example that I have used uses the 'Adapter.IGS' model that is installed by default with SprutCAM.
I start the tutorial with the datum already set as 'middle - middle - max' for the X - Y - Z axes, which for this example is not very useful, and is another example of where the normal datum setting method cannot be used.
You can view the video here
I hope you find it useful. If you have any questions about this, feel free to post them up.
Edited by - sprut_uk on 25/05/2005 10:32:13
post May 27 2005, 11:11 PM
Very useful
I guess the 4 axis machining works sort of the same way too
Thanks Dave
Krisztian Toth
Tokay Tech Inc.
http://www.cnc-programming.com
http://www.sprut.ca
post May 28 2005, 03:29 PM
Hi Krisz,
Yes, If you need to find the centre of the rotational (4th) axis, then this method can be used to good effect.
post Jun 1 2005, 11:08 AM
That is great
I would like to see more videos about 4 and 5 axis machining because some parts of that is still not clear for me.
For example if you do a rotation after you set your xyz zero position will your zero positions move as with the rotation or they will stay at the same position etc.
I dont think the manual goes into too much details about the multy axis machining.
Also i would like to see a better explonation of the Job list in the machining tab.
Krisztian Toth
Tokay Tech Inc.
http://www.sprut.ca
Lo-Fi Version Time is now: 21st March 2019 - 08:19 PM
