> Waterline roughing - milling slots?
post Sep 2 2013, 09:28 PM
I'm trying to use a roughing waterline operation in SC7 to mill out 3 open-ended slots in a part. I've created a roughing waterline operation for the 1st slot, selected the floor of the slot as the pocket and "run" it from the machining tab, which seems to work fine. I copied that operation to make a new waterline roughing op, selected the floor for the 2nd slot, and "run' that operation. This results in a bizarre set of toolpaths that mill around part of the edge of the part and then creates some diagonal toolpaths over part of the 3rd slot.
Why the heck does SC insist on creating these toolpaths? All I want it to do is mill out the open slots, one at a time. Can someone please take a look at the attached file and tell me what I'm doing wrong. This worked fine in an earlier revision of the file using an older part design.
Attached File  Wire_Support___Vertical_Top_Rev_4_Slots.zip ( 288.45K ) Number of downloads: 3
post Sep 3 2013, 06:50 AM
Hi Mike,
I simply created a new operation to replace the faulty one and it worked correctly.
I would suggest that you send this to your SprutCAM reseller or direct to Sprut themselves with a full explanation of how you created this project in the first place.
There appears to be artefacts remaining from a previous SprutCAM project that this project was previously used for?
My own preference for 'reusing' a SprutCAM project is to start a new project, import the new model and then use the 'Import operation' option and select the existing SprutCAM project to be used as the 'template' for the new one.
post Sep 3 2013, 01:23 PM
I'd taken a similar SC STC file, done a save-as on it, deleted the old model and imported a new revision of the same model. This has worked well for me before, but apparently something about this geometry made it fail this time. I'll try switching to your approach of importing the ops into a new file, rather than importing the new model into an old file. Thanks for the help.
Lo-Fi Version Time is now: 20th July 2019 - 05:11 AM
