> Setting default rapid speeds for a given machine
post Jul 21 2014, 06:14 PM
Is there a way to set the default rapid speeds for a given machine in SprutCAM 8 so that they are already populated when SC8 is started and a new project created?
At present, they default to 10,000 mm/min and I'd like to change them to 90 ipm.
post Jul 28 2014, 05:27 PM
Hi Mike,
I'm a little confused abiout your question. Are you saying that you are running SprutCAM in metric units (10,000mm/min) and want a 90 ipm feedrate?
It is possible to create a different default rapid rate via the xml file for the particular machine configuration that you are using, but the configurations are always created in metric and SprutCAM changes the units as appropriate for a project.
I think that you would need to add a rapid vale of 2,286mm/min.
I cannot remember the format required for setting this within an xml file so you might want to contact your SprutCAM reseller for pointers on this.
post Aug 10 2014, 05:33 PM
QUOTE (Sprut_UK @ Jul 28 2014, 05:27 PM) *
Hi Mike, I'm a little confused abiout your question. Are you saying that you are running SprutCAM in metric units (10,000mm/min) and want a 90 ipm feedrate? It is possible to create a different default rapid rate via the xml file for the particular machine configuration that you are using, but the configurations are always created in metric and SprutCAM changes the units as appropriate for a project. I think that you would need to add a rapid vale of 2,286mm/min. I cannot remember the format required for setting this within an xml file so you might want to contact your SprutCAM reseller for pointers on this. I hope this helps. Dave
I use Imperial units, which seems to create problems with SC in all of its version from SC 4 onward. I've attached a screen grab of the machine setup the way I currently have it configured. I've got Measurements parameters set to Imperial (in, ft/min, in/min, in/tooth, etc.). Under Schema | Visual Properties, SC 8 defaults to 10,000 for Rapid Feed with no units given and I'm assuming SC 8 sees that as 10,000 mm/min because when I create a machining operation the rapid there defaults to 394 ipm. Below that setting, there are also parameters for Rapid Feed in the Z, Y, and X axes which also default to 10,000. I've tried changing all of those to lower values but they never seem to take and revert back to 10,000 the next time I load SC 8.
Do you think that changing the default rapid in the XML file is the most likely path to success? If so, I can pursue that with my reseller.
Attached File  SC8_Tormach_Machine_Setup___Default_Rapids.JPG ( 128.09K ) Number of downloads: 4
post Aug 11 2014, 05:17 AM
QUOTE (Mike Henry @ Aug 10 2014, 06:33 PM) *
post Aug 13 2014, 06:14 PM
QUOTE (Sprut_UK @ Aug 11 2014, 05:17 AM) *
Thanks Dave.
Lo-Fi Version Time is now: 17th June 2019 - 06:58 AM
