> Turn material feature not working?, as expected for mill ops?
post Feb 15 2016, 07:12 PM
I have a question, it seems that using a dxf to "turn" your part instead of say square or extrude does not work at all?
the stock material seems to appear proper but when you run the operation or do the simulation it is completely turned 90 deg
I believe this has not worked since I remeber but I think there is no reason for it to not function
because I want to take a part from lathe, and then do a mill op, but I wish to turn the sketch from the lathe finished part, then do the mill op as in the example cut a slot a cross (made up example)
I included all the files, from the GM to iges (which SC10 broke the import on) to step (works) to dxf
post Feb 19 2016, 05:44 PM
anyone tried this? added pic
post Feb 22 2016, 10:42 AM
Yes I have tried it. It doesn't have anything to do with dxf, it happens with standard curves and faces too. This needs to be reported to your SprutCAM reseller.
In the attached modified version of your project I have projected the top faces of the inner ring to create two curves which I have then extruded to create your workpiece correctly.
post Feb 24 2016, 05:03 PM
QUOTE (Sprut_UK @ Feb 22 2016, 03:42 AM) *
Thank you, yes they are aware of it now.
I did the dummy machining ops before, but now im simply importing a model that is without the desired operations as the workpiece, I had tried in past to do that but did not now that I had to select all the faces for it to work. This works nicely for now, if I have the original model in my native CAD system and can easily manipulate it to the state that I desire. If not then the turn/extrude are the best options (when turn gets fixed)
Lo-Fi Version Time is now: 17th July 2019 - 10:36 PM
