> Sprut 8 - 3 axis mill, Spindle should be Z
Dave Hall
post Dec 7 2013, 10:50 AM
Hello Folks
I've searched in a few places to find how to change the tool axis from Y to Z.
The CAM package I used before had a setup box "Spindle is Z".
Looked around the generic Sprut 3 axis mill set up without success.
The reason being that a part that I'm using to get started with Sprut was developed with its tool paths about Y axis - any simple fix for this little issue thanks?
rgds Dave.
post Dec 8 2013, 06:51 PM
QUOTE (Dave Hall @ Dec 7 2013, 10:50 AM) *
Hello Folks
rgds Dave.
Just guessing here, but maybe you have the wrong machine specified in the machining tab?
post Dec 10 2013, 08:02 AM
SprutCAM includes plenty of machine configurations, and as Mike eluded to, you will need to use a different machine configuration to be able to use a different tool axis.
I do have a customer who is using a Universal type machine that can change the tool axis from Z to Y. I seem to remember that he uses a rotated LCS within SprutCAM when he's machining with the Y axis and his postprocessor outputs a 'rotated plane' command in the subsequent g-code which takes care of it.
I assume that you want to use the existing un-rotated coordinate system (X/Y/Z) with the tool working on the Y axis? This should be achieveable, but a machine configuration might be required to do it.
This can be made selectable..........the latest Tormach machine configuration includes a selectable (Kress) spindle axis (see attachment).
Lo-Fi Version Time is now: 18th July 2019 - 10:58 AM
