> output tool call command when using same tool
breazr
post Sep 29 2017, 06:24 PM
Hello Dave,
It seems logic not to output a new "tool call" (LOADTL) command when using the same tool for a new operation (unnecessary move to tool change position, activating tool length compensation and so other).
However, for some Heidenhain controllers, especially when 5-axis milling is involved, not issuing a new "tool call" command in the NC program can cause some problems.
Is there any possibility to force the attached post to issue the tool call command, for a new operation, even the tool is the same ?
Of course, only if the change is a simple one, if it requires some complex work, I will contact the guys from SprutCAM and ask the customer to pay for that change.
For example, I have commented the line:
if t$<>"" then
from the "Loadtl" function, but it didn't work (not correct ? not enough ?)
Radu
Attached File  Heidenhain__iTNC530__Mill_modif_51.zip ( 14.31K ) Number of downloads: 1
post Oct 9 2017, 06:13 PM
Hi Radu,
It wont be a simple modification to get the TOOL CALL output into the code without a toolchange command. As you say, it is the Loadtl section of the post that creates the TOOL CALL output, but if you aren't changing tools, this negates simply using this because the Loadtl section will not be in the Cldata.
My suggestion is; if you require the TOOL CALL for 5D milling, you could create a routine in the PPFUN section to check the '.name' of the current operation and then output the TOOL CALL conditionally based on this?. The PPFUN Cldata contains the current Tool number (CLD[26]), Tool Diameter (CLD[27]) and the tool length (CLD[33]) if needed.
Alternatively, if you are using TCPM, you could do something in the 'Interpolation' section of the post.
breazr
post Oct 31 2017, 09:57 AM
QUOTE (Sprut_UK @ Oct 9 2017, 06:13 PM) *
Hi Radu,
Hello Dave,
First of all, thanks for posting a reply !
I run into this reply only today (my fault for not visiting this forum more often!) so I have to check if I am able to develop a solution based upon your advices.
I will keep you informed.
Radu
Lo-Fi Version Time is now: 19th January 2019 - 10:11 AM
