> Controlling adaptive ruffing lead in and lead out., Controlling adaptive ruffing lead in and lead out.
post Feb 2 2016, 06:29 AM
Hi. I ran into a problem in SC9 were I want to use adaptive ruffing but the part needs to be below the surface of the jaws. Even though I defined a restricted zone the program keeps placing the start of the cutter were the vice jaw will be. See attached picture. The operation is disable. Its called "ruffing slot".
I've attached the SC file. Any help would be great.
Attached File  335462_Rev_01_missing_features.stc ( 307.48K ) Number of downloads: 2
post Feb 16 2016, 08:43 AM
You cannot use the 'Restrict zone' feature to keep machining 'within' an area, you can only use it to exclude machining from an area.
In the attached modified version of you project I have 'Joined' your original 2D geometry that you were using to create a closed boundary I have then used this to 'Extrude' a fixture (Hole) to restrict your machining. You can also add extra 'stock' to this to give yourself an extra safety margin if required.
I have added the extruded fixture to the machine itself (top of machining list). All of the subsequent operations automatically inherit this fixture. You can remove a fixture from a subsequent operation by selecting the operations fixture list and deleting the 'Fixtures of the previous operation' option.
Attached File  335462_Rev_01_missing_features_dp.stc ( 337.06K ) Number of downloads: 6
Lo-Fi Version Time is now: 20th April 2019 - 08:13 PM
