> Updated to SC9 now get errors with old post. Can not do canned cycles any more
post Dec 28 2015, 11:31 PM
HI, just upgraded from SC8 to SC9. The post I had for the Haas which had worked fine now in SC9 will not properly output canned cycles such as drilling and tapping. See attached screen shot for error message.
Error interpreting SSP file.
[ERROR] OUT_TOOL_IST (13:0) CLDFILE operator error:
incorrect parameters
I've attached the post processor.
Attached File  Error_with_postprocessor.jpg ( 365.46K ) Number of downloads: 2
Attached File  HAAS_4thaxis_4decimal.spp ( 20.94K ) Number of downloads: 3
post Dec 28 2015, 11:36 PM
QUOTE (Bob Gray @ Dec 28 2015, 02:31 PM) *
Opps uploaded the old Post file. Look at the one with modified in the name.
post Dec 29 2015, 08:02 AM
I suspect that you need to change the drilling 'cycle format' in SprutCAM. Older SprutCAM postprocessors could still be using the CYCLE format instead of the later EXTCYCLE format. If you check the SprutCAM help files under 'Hole machining operation' you will see an explanation of this.
I have attached a screengrab of this.
I suspect that you need to set the default method under 'System setup' which will default to 'EXTCYCLE'.
post Dec 30 2015, 06:18 AM
I tried that fix and another that I read about on CNCzone. The fix you suggested did nothing to fix the error. The post that they suggested on CNCzone fixed the error but I still do not get the canned cycle inserted into code. See attached screen shot.
I just need a working post for a Haas VF2, Mini Mill
QUOTE (Sprut_UK @ Dec 28 2015, 11:02 PM) *
post Dec 30 2015, 06:19 AM
QUOTE (Bob Gray @ Dec 29 2015, 09:18 PM) *
Forgot to hit the upload buttom
Attached File  Canned_Cycle_problem.jpg ( 366.21K ) Number of downloads: 5
post Dec 30 2015, 01:18 PM
That is very strange because it fixed it here. You did recalculate the toolpaths after making the change didn't you? If you didn't, the problem will persist because it is part of the already calculated toolpaths.
Your last screengrab image doesn't show the CLData as this would show whether there are CYCLE or EXTCYCLE commands being created.
You could also select the 'Long hand' option for the 'NC Code format' as a workaround, although this will not work for tapping.
The attached modified version of your post includes the alteration required to avoid the error message........although this is not related to the lack of cycle output.
post Jan 6 2016, 06:49 AM
I must not have recalculated the tool paths. I could have sworn I hit reset and recal the tool paths. Maybe a full off was needed. But I tried it again tonight and it worked fine. I still get the error message with the unmodified post. But least I'm getting my canned cycles which means tapping.
Oh I looked, I did not see the attachment that you mentioned in your post.
QUOTE (Sprut_UK @ Dec 30 2015, 05:18 AM) *
post Jan 6 2016, 04:12 PM
Thanks for the update. Not sure what happened to the previous attachment...........hopefully it will be attached to this time........
Lo-Fi Version Time is now: 20th April 2019 - 08:13 PM
