> switched to SC 9, robot tool orientation hosed, tool orientation and position messed up!
post Jan 10 2015, 08:11 PM
I was working in SC8 last week....my registration got hosed and could not longer open the program at all. I figured I'd upgrade to version 9, and now I am completely hosed. I am using a Kuka robot arm, and I cannot get the tool orientation and position right. I know this process works, I've done plenty of cuts in version 8! I've attached my project file, screenshots that show something weird going on, and my robot's configuration file. There's gotta be some step I'm missing here.
Please see the the attached images. When I select the robot itself in the tree, the darn tooltip jumps up (in the Z world-axis) to the very center of the end flange. Then if I click on the toolpath itself, the tooltip jumps down to the correct place. This happens EVERYTIME!
I need to get this resolved. Please help! My router sticks out from the flange-edge 127 mm, and the bottom of the tooltip is 170 mm down from the center of the end-flange. That should be really simple, but SC9 is just driving me crazy!!!!
Attached File  SC_tool_in_correct_position_when_toolpath_selected.JPG ( 83.53K ) Number of downloads: 14
Attached File  SC_tool_origin_is_off_when_robot_selected.JPG ( 54.62K ) Number of downloads: 13
post Jan 12 2015, 03:50 PM
I am no expert with the Sprut Robot stuff. Have you contacted your SprutCAM reseller for support?
You will need to provide the complete machine configuration folder and not just the xml file. The robot images (*.osd) are not included with the xml file.
vvelikov
post Jan 13 2015, 10:02 AM
QUOTE (neeboy @ Jan 10 2015, 08:11 PM) *
You need to do a proper configuration file.
I doubt this data you have for the tool is real - X 0 means the tool is ON the flange - that is the zero of the robot tool ... same about Y?
Did you put the actual data from your tool on the robot?
This includes the tool dimensions AND the orientation - the tool calibration should be done as per the instructions for Sprutcam.
And in Sprutcam 9 there is a new version of the machine data file - check it out and use it instead of the old (v8) machine data file
A about the tool - it jumps down when you select a toolpath as you have a tool length there. In the machine definition you dont have any tool attached.
Lo-Fi Version Time is now: 20th April 2019 - 08:56 PM
