> Cutter comp Diameter not changing
post Aug 28 2014, 05:39 PM
Hi, I wrote a short program in which I used the same tool to do both the inside bore and the outside contour. Since I needed to comp both values I used two different operations. The first operation used D8 the second used D18. All set under the tool parameters screen. When the code was output I took a quick look at it and noticed that D18 was not present for the second operation. Is this a software issue or a post processor issue?
I'm running Sprutcam 8 Version 2 Build 74725 RL 23/7/2014
(Contouring inside boars)
G54
T08 M06
(@3/16)
G00 G90 G54 X2.5678 Y-0.5189
S4000 M03
G43 H08 Z0.1
G40 M08
G01 F12.
Z0.
G41 D08 X2.5811 Y-0.5057
(Contouring outside Radius correction number 18)
G54
T08 M06
(@3/16)
G00 G90 G54 X0.0513 Y-1.3448
S4000 M03
G43 H08 Z0.1
G40 M08
G01 F12.
Z0.
G41 X0.07
post Aug 29 2014, 02:45 AM
I would suggest that you first check the postprocessor. Sometimes they are set so that the D value uses the tool number.
Lo-Fi Version Time is now: 22nd July 2019 - 09:37 AM
