> Need B axis Reversed
ka67_72
post Jan 28 2015, 06:17 PM
How can I configure Sprutcam or the postprocessor to rotate my B axis in the opposite direction? Positive is currently counterclockwise in Sprutcam but is clockwise in my machine.
Kevin
post Jan 28 2015, 08:48 PM
Hi Kevin,
I'm assuming that you are using one of the standard machine configurations, the easiest way to achieve this is to change the machine configuration that you are using to the opposite option.
For example if you are using 4-axis milling machine (A) change this to 4-axis milling machine (-A)
You will need to recalculate the cutterpaths before postprocessing the g-code.
ka67_72
post Jan 29 2015, 03:11 AM
It's my own. I used the demo of machine maker. I've been using 3+2 and editing the code by hand. I want to play with some simultaneous stuff. Do I need to edit the xml?
Kevin
post Jan 29 2015, 06:03 AM
Hi Kevin,
Yes you will need to edit your machines xml file.
You will need to scale the required axis by -1 (or 1 if it is already reversed).
Here is an example of a reversed C axis direction found in the 'Schema' section:
<ImageFile DefaultValue="Caxis.osd"/>
<AxisType DefaultValue="Rotary"/>
<Scale DefaultValue="-1"/>
<ParameterName DefaultValue="AxisCPos"/>
ka67_72
post Mar 9 2015, 10:46 PM
I finally got back to this last night. It changed the rotation but also rotated my origin 180 degrees about Y and moved it down 25 mm. It also moved some other things around. Reference attached screen captures. 5d is the scaled one. Is there a document that explains the details of the xml files?
Kevin
After some more experimenting, it seems to do this to every copy I add no matter what I do to the xml file. Even if I don't edit it.
ka67_72
post Mar 10 2015, 01:23 AM
I got it working after finding the machine file it was actually using. Anytime I tried to use a modified copy it screwed up. I finally got the nerve to modify the existing one and it works as you described. For a while everything was screwed up and my parts from all my previous work were floating about 3' off the table. I thought all was lost. Hopefully 5d will reduce hand finishing times. Pic is of a 3+2 machined part.
Kevin
post Mar 11 2015, 08:57 AM
QUOTE (ka67_72 @ Mar 10 2015, 01:23 AM) *
Kevin
Hi Kevin,
Thanks for the update. The way machine configurations work in SprutCAM can be a bit 'cluncky'. There's no doubt that they work and they work very well, but getting them setup or adjusted can seem to be a 'black art' at times especially for the end user.
The lead programmer at Sprut has indicated to me that he would like to use a different approach for this feature in the future.............let's hope that this future is not too far off wink.gif
Thanks for the picture of the finished part, that looks very cool! Do you have any more images of it that you would like to share?
ka67_72
post Mar 27 2015, 01:24 AM
Pics can be seen here: http://www.carterperformance.com/store/p1/...ottle_Body.html
Kevin
QUOTE (Sprut_UK @ Mar 11 2015, 03:57 AM) *
Hi Kevin,
ka67_72
post Apr 7 2015, 12:46 AM
Better pics can be seen here: http://www.carterperformance.com/photo-gallery.html
Kevin
Lo-Fi Version Time is now: 22nd July 2019 - 09:47 AM
