2 Pages V   1 2 >
> sprutcam 8 tool librabry isue
TPR
post Mar 15 2013, 12:36 AM
2 issues with my tool library
first one is that i do not see all my tools from my machining tab, only way to see them all is to go to my machine and hit work with tool library and then i will see them all which doesnt help me since i cannot select my tool from the machining tab because they dont show up there.
second issue is i get a error window when i try to edit my tool library after i hit replace, attached is a screen shot of my error
any help would be great
thanks guys
Carlos A. Diaz
TPR Motorsports
803.334.8674
TPR
post Mar 15 2013, 12:40 AM
this is what my tool library looks like from my machining tab, clearly there are tools missing
thanks guys
Attached File  tool_library_issue__02.jpg ( 299.47K ) Number of downloads: 19
Carlos A. Diaz
TPR Motorsports
803.334.8674
post Mar 15 2013, 09:51 PM
Hi TPR, welcome to the SprutCAM forum.
The first thing to check is that SprutCAM 8 is running with full administrator rights. The best way of doing this, if you don't already know, is to create a shortcut for SprutCAM 8, then right click the shortcut and select 'Properties' from the menu on the 'Shortcut' tab in the window that opens. Now click 'Advanced' and select the 'Run as administrator' option and then close these windows.
It also best to install SprutCAM 8 with full administrator rights too.
I hope this helps. Let us know how you are getting on with this problem.
TPR
post Apr 3 2013, 08:36 PM
QUOTE (Sprut_UK @ Mar 15 2013, 05:51 PM) *
i was starting to think i wasnt getting no sprutcam love but i see u posted some time ago, i didnt have my notifications turned on... lol
thank you for the reply, how do i know if i installed it with full administrative right or not?
is there a link i can use to install the lastest release of sprutcam 8?
thanks again
Carlos A. Diaz
TPR Motorsports
803.334.8674
post Apr 3 2013, 09:08 PM
I created this narrated video tutorial for my customers about applying Admin rights when using SprutCAM 7, but the same 'rules' apply for SprutCAM 8 too: http://www.download.sprut.co.uk/Forum_vide...inistrator.html
You can always download this file to install the latest build of SprutCAM 8.
When you run this file, it will check which files require updating in your installation, it will then download the updated files and install them for you.
This is of course assuming that your PC that is running SprutCAM 8 has an internet connection, if not then you can download an archived version of the installer here: http://download.sprutcam.com/download/spru...lease_EN_RU.zip which can then be transferred to the non internet connected PC via a USB memory stick or something similar to enable the installation of SprutCAM 8.
TPR
post Apr 12 2013, 12:43 PM
QUOTE (Sprut_UK @ Apr 3 2013, 05:08 PM) *
In the latest Nightbuild version there is a new option to update your installation from within SprutCAM 8: 'Help' - 'Updates', or click on the icon in the bottom right of the main SprutCAM window.
This is of course assuming that your PC that is running SprutCAM 8 has an internet connection, if not then you can download an archived version of the installer here: http://download.sprutcam.com/download/spru...lease_EN_RU.zip which can be transferred to the non internet connected PC via a USB memory stick or something similar to enable the installation of SprutCAM 8.
thank you!
Carlos A. Diaz
TPR Motorsports
803.334.8674
TPR
post Apr 16 2013, 01:17 PM
QUOTE (TPR @ Apr 12 2013, 08:43 AM) *
thank you!
i changed my permissions to administrator and reinstalled as a administrator, still the same issue where i dont see all my tools under the machining tab, now if i go to the tormach machine tab, then machine libraries and go to milling tools, i can see all my tools, this was true also even before changing my permissions to administrator, but if i try to edit them i get the same error message.
can u provide a link to the latest release of sprutcam 8? i'll try and reinstall it all over again with administrator previlaedges and all that.
thank you
Carlos A. Diaz
TPR Motorsports
803.334.8674
post Apr 16 2013, 02:41 PM
The SprutCAM 8 download link is in my previous reply (above). Did you create this tool library directly in SprutCAM 8?
TPR
post Apr 17 2013, 03:48 AM
QUOTE (Sprut_UK @ Apr 16 2013, 10:41 AM) *
yes, the library was created per eric andersons video on tormach.com
i have come across another issue, i did a program and in the simulation the tool changes take places and the next tool cuts like its suppose to but when i went out to my shop after the first tool change there seems to be a large gap between the tool and the material almost as if the first tool is longer than its suppose to be, i double checked tool lengths and they are all correct. could this issue be related to the library issue???? please help
thank you
Carlos A. Diaz
TPR Motorsports
803.334.8674
TPR
post Apr 17 2013, 04:08 AM
here is my program
Oracepak-fixture-01
(Tool) (7) (Diameter)(0.5) (@.5" BN EM) (Operation) (2D contouring)
(Tool) (7) (Diameter)(0.5) (@.5" BN EM) (Operation) (2D contouring3)
(Tool) (6) (Diameter)(0.25) (@.25" BN EM) (Operation) (2D contouring2)
(Tool) (12) (Diameter)(0.108) (@.108" center drill) (Operation) (Hole machining)
(Tool) (18) (Diameter)(0.25) (@.25" chamfering 90 degree) (Operation) (2D contouring4)
N10 (Postprocessor: )
N20 G90 G54 G64 G50 G17 G40 G80 G49
N30 G20 (Inch)
(2D contouring)
N40 G54
N50 M998
N60 T7 G43 H7 M6
(.5" BN EM)
N70 S2500 M8 M3
N80 G0 G94
N90 X-0.8537 Y1.0593 Z0.1
N100 G1 Z-0.0417 F2
N110 G2 X-0.8752 Y1.059 Z-0.0417 I-0.03 J1.4997 F18
N120 X-0.8752 Y-1.059 Z-0.0417 I-1.9852 J-1.059
N130 X-0.2075 Y-1.2201 Z-0.0417 I-0.0085 J-1.5
N140 X0.2075 Y-1.2201 Z-0.0417 I0.2075 J-0.4549
N150 X0.8752 Y-1.059 Z-0.0417 I0.6762 J-1.3389
N160 X0.8752 Y1.059 Z-0.0417 I1.9852 J1.059
N170 X0.2075 Y1.2201 Z-0.0417 I0.0086 J1.5
N180 X-0.2075 Y1.2201 Z-0.0417 I-0.2075 J0.4549
N190 X-0.8431 Y1.0596 Z-0.0417 I-0.6762 J1.3389
N200 G1 X-0.8537 Y1.0593
N210 Z-0.0833 F2
N220 G2 X-0.8752 Y1.059 Z-0.0833 I-0.03 J1.4997 F18
N230 X-0.8752 Y-1.059 Z-0.0833 I-1.9852 J-1.059
N240 X-0.2075 Y-1.2201 Z-0.0833 I-0.0085 J-1.5
N250 X0.2075 Y-1.2201 Z-0.0833 I0.2075 J-0.4549
N260 X0.8752 Y-1.059 Z-0.0833 I0.6762 J-1.3389
N270 X0.8752 Y1.059 Z-0.0833 I1.9852 J1.059
N280 X0.2075 Y1.2201 Z-0.0833 I0.0086 J1.5
N290 X-0.2075 Y1.2201 Z-0.0833 I-0.2075 J0.4549
N300 X-0.8431 Y1.0596 Z-0.0833 I-0.6762 J1.3389
N310 G1 X-0.8537 Y1.0593
N320 Z-0.125 F2
N330 G2 X-0.8752 Y1.059 Z-0.125 I-0.03 J1.4997 F18
N340 X-0.8752 Y-1.059 Z-0.125 I-1.9852 J-1.059
N350 X-0.2075 Y-1.2201 Z-0.125 I-0.0085 J-1.5
N360 X0.2075 Y-1.2201 Z-0.125 I0.2075 J-0.4549
N370 X0.8752 Y-1.059 Z-0.125 I0.6762 J-1.3389
N380 X0.8752 Y1.059 Z-0.125 I1.9852 J1.059
N390 X0.2075 Y1.2201 Z-0.125 I0.0086 J1.5
N400 X-0.2075 Y1.2201 Z-0.125 I-0.2075 J0.4549
N410 X-0.8431 Y1.0596 Z-0.125 I-0.6762 J1.3389
N420 G1 X-0.8537 Y1.0593
N430 Z-0.1667 F2
N440 G2 X-0.8752 Y1.059 Z-0.1667 I-0.03 J1.4997 F18
N450 X-0.8752 Y-1.059 Z-0.1667 I-1.9852 J-1.059
N460 X-0.2075 Y-1.2201 Z-0.1667 I-0.0085 J-1.5
N470 X0.2075 Y-1.2201 Z-0.1667 I0.2075 J-0.4549
N480 X0.8752 Y-1.059 Z-0.1667 I0.6762 J-1.3389
N490 X0.8752 Y1.059 Z-0.1667 I1.9852 J1.059
N500 X0.2075 Y1.2201 Z-0.1667 I0.0086 J1.5
N510 X-0.2075 Y1.2201 Z-0.1667 I-0.2075 J0.4549
N520 X-0.8431 Y1.0596 Z-0.1667 I-0.6762 J1.3389
N530 G1 X-0.8537 Y1.0593
N540 Z-0.2084 F2
N550 G2 X-0.8752 Y1.059 Z-0.2084 I-0.03 J1.4997 F18
N560 X-0.8752 Y-1.059 Z-0.2084 I-1.9852 J-1.059
N570 X-0.2075 Y-1.2201 Z-0.2084 I-0.0085 J-1.5
N580 X0.2075 Y-1.2201 Z-0.2084 I0.2075 J-0.4549
N590 X0.8752 Y-1.059 Z-0.2084 I0.6762 J-1.3389
N600 X0.8752 Y1.059 Z-0.2084 I1.9852 J1.059
N610 X0.2075 Y1.2201 Z-0.2084 I0.0086 J1.5
N620 X-0.2075 Y1.2201 Z-0.2084 I-0.2075 J0.4549
N630 X-0.8431 Y1.0596 Z-0.2084 I-0.6762 J1.3389
N640 G1 X-0.8537 Y1.0593
N650 Z-0.25 F2
N660 G2 X-0.8752 Y1.059 Z-0.25 I-0.03 J1.4997 F18
N670 X-0.8752 Y-1.059 Z-0.25 I-1.9852 J-1.059
N680 X-0.2075 Y-1.2201 Z-0.25 I-0.0085 J-1.5
N690 X0.2075 Y-1.2201 Z-0.25 I0.2075 J-0.4549
N700 X0.8752 Y-1.059 Z-0.25 I0.6762 J-1.3389
N710 X0.8752 Y1.059 Z-0.25 I1.9852 J1.059
N720 X0.2075 Y1.2201 Z-0.25 I0.0086 J1.5
N730 X-0.2075 Y1.2201 Z-0.25 I-0.2075 J0.4549
N740 X-0.8431 Y1.0596 Z-0.25 I-0.6762 J1.3389
N750 G1 X-0.8537 Y1.0593
N760 G0 Z0.1
N770 (Inch)
N780 (Inch)
(2D contouring3)
(.5" BN EM)
N790 G0 F18
N800 X-1.414 Y-2.0286 F18
N810 G1 Z-0.0417 F2
N820 G2 X-2.0407 Y-1.2563 Z-0.0417 I-0.3535 J0.3536 F18
N830 G3 X-2.0407 Y1.2563 Z-0.0417 I-0.8196 J1.2563
N840 G2 X-1.414 Y2.0286 Z-0.0417 I0.2732 J0.4188
N850 G3 X-0.3535 Y2.0286 Z-0.0417 I0.5303 J0.5304
N860 G2 X0.3535 Y2.0286 Z-0.0417 I0.3535 J-0.3536
N870 G3 X1.414 Y2.0286 Z-0.0417 I0.5303 J0.5304
N880 G2 X2.0407 Y1.2563 Z-0.0417 I0.3535 J-0.3536
N890 G3 X2.0407 Y-1.2563 Z-0.0417 I0.8197 J-1.2562
N900 G2 X1.414 Y-2.0286 Z-0.0417 I-0.2732 J-0.4187
N910 G3 X0.3535 Y-2.0286 Z-0.0417 I-0.5302 J-0.5304
N920 G2 X-0.3535 Y-2.0286 Z-0.0417 I-0.3535 J0.3536
N930 G3 X-1.414 Y-2.0286 Z-0.0417 I-0.5302 J-0.5304
N940 G1 Z-0.0833 F2
N950 G2 X-2.0407 Y-1.2563 Z-0.0833 I-0.3535 J0.3536 F18
N960 G3 X-2.0407 Y1.2563 Z-0.0833 I-0.8196 J1.2563
N970 G2 X-1.414 Y2.0286 Z-0.0833 I0.2732 J0.4188
N980 G3 X-0.3535 Y2.0286 Z-0.0833 I0.5303 J0.5304
N990 G2 X0.3535 Y2.0286 Z-0.0833 I0.3535 J-0.3536
N1000 G3 X1.414 Y2.0286 Z-0.0833 I0.5303 J0.5304
N1010 G2 X2.0407 Y1.2563 Z-0.0833 I0.3535 J-0.3536
N1020 G3 X2.0407 Y-1.2563 Z-0.0833 I0.8197 J-1.2562
N1030 G2 X1.414 Y-2.0286 Z-0.0833 I-0.2732 J-0.4187
N1040 G3 X0.3535 Y-2.0286 Z-0.0833 I-0.5302 J-0.5304
N1050 G2 X-0.3535 Y-2.0286 Z-0.0833 I-0.3535 J0.3536
N1060 G3 X-1.414 Y-2.0286 Z-0.0833 I-0.5302 J-0.5304
N1070 G1 Z-0.125 F2
N1080 G2 X-2.0407 Y-1.2563 Z-0.125 I-0.3535 J0.3536 F18
N1090 G3 X-2.0407 Y1.2563 Z-0.125 I-0.8196 J1.2563
N1100 G2 X-1.414 Y2.0286 Z-0.125 I0.2732 J0.4188
N1110 G3 X-0.3535 Y2.0286 Z-0.125 I0.5303 J0.5304
N1120 G2 X0.3535 Y2.0286 Z-0.125 I0.3535 J-0.3536
N1130 G3 X1.414 Y2.0286 Z-0.125 I0.5303 J0.5304
N1140 G2 X2.0407 Y1.2563 Z-0.125 I0.3535 J-0.3536
N1150 G3 X2.0407 Y-1.2563 Z-0.125 I0.8197 J-1.2562
N1160 G2 X1.414 Y-2.0286 Z-0.125 I-0.2732 J-0.4187
N1170 G3 X0.3535 Y-2.0286 Z-0.125 I-0.5302 J-0.5304
N1180 G2 X-0.3535 Y-2.0286 Z-0.125 I-0.3535 J0.3536
N1190 G3 X-1.414 Y-2.0286 Z-0.125 I-0.5302 J-0.5304
N1200 G1 Z-0.1667 F2
N1210 G2 X-2.0407 Y-1.2563 Z-0.1667 I-0.3535 J0.3536 F18
N1220 G3 X-2.0407 Y1.2563 Z-0.1667 I-0.8196 J1.2563
N1230 G2 X-1.414 Y2.0286 Z-0.1667 I0.2732 J0.4188
N1240 G3 X-0.3535 Y2.0286 Z-0.1667 I0.5303 J0.5304
N1250 G2 X0.3535 Y2.0286 Z-0.1667 I0.3535 J-0.3536
N1260 G3 X1.414 Y2.0286 Z-0.1667 I0.5303 J0.5304
N1270 G2 X2.0407 Y1.2563 Z-0.1667 I0.3535 J-0.3536
N1280 G3 X2.0407 Y-1.2563 Z-0.1667 I0.8197 J-1.2562
N1290 G2 X1.414 Y-2.0286 Z-0.1667 I-0.2732 J-0.4187
N1300 G3 X0.3535 Y-2.0286 Z-0.1667 I-0.5302 J-0.5304
N1310 G2 X-0.3535 Y-2.0286 Z-0.1667 I-0.3535 J0.3536
N1320 G3 X-1.414 Y-2.0286 Z-0.1667 I-0.5302 J-0.5304
N1330 G1 Z-0.2084 F2
N1340 G2 X-2.0407 Y-1.2563 Z-0.2084 I-0.3535 J0.3536 F18
N1350 G3 X-2.0407 Y1.2563 Z-0.2084 I-0.8196 J1.2563
N1360 G2 X-1.414 Y2.0286 Z-0.2084 I0.2732 J0.4188
N1370 G3 X-0.3535 Y2.0286 Z-0.2084 I0.5303 J0.5304
N1380 G2 X0.3535 Y2.0286 Z-0.2084 I0.3535 J-0.3536
N1390 G3 X1.414 Y2.0286 Z-0.2084 I0.5303 J0.5304
N1400 G2 X2.0407 Y1.2563 Z-0.2084 I0.3535 J-0.3536
N1410 G3 X2.0407 Y-1.2563 Z-0.2084 I0.8197 J-1.2562
N1420 G2 X1.414 Y-2.0286 Z-0.2084 I-0.2732 J-0.4187
N1430 G3 X0.3535 Y-2.0286 Z-0.2084 I-0.5302 J-0.5304
N1440 G2 X-0.3535 Y-2.0286 Z-0.2084 I-0.3535 J0.3536
N1450 G3 X-1.414 Y-2.0286 Z-0.2084 I-0.5302 J-0.5304
N1460 G1 Z-0.25 F2
N1470 G2 X-2.0407 Y-1.2563 Z-0.25 I-0.3535 J0.3536 F18
N1480 G3 X-2.0407 Y1.2563 Z-0.25 I-0.8196 J1.2563
N1490 G2 X-1.414 Y2.0286 Z-0.25 I0.2732 J0.4188
N1500 G3 X-0.3535 Y2.0286 Z-0.25 I0.5303 J0.5304
N1510 G2 X0.3535 Y2.0286 Z-0.25 I0.3535 J-0.3536
N1520 G3 X1.414 Y2.0286 Z-0.25 I0.5303 J0.5304
N1530 G2 X2.0407 Y1.2563 Z-0.25 I0.3535 J-0.3536
N1540 G3 X2.0407 Y-1.2563 Z-0.25 I0.8197 J-1.2562
N1550 G2 X1.414 Y-2.0286 Z-0.25 I-0.2732 J-0.4187
N1560 G3 X0.3535 Y-2.0286 Z-0.25 I-0.5302 J-0.5304
N1570 G2 X-0.3535 Y-2.0286 Z-0.25 I-0.3535 J0.3536
N1580 G3 X-1.414 Y-2.0286 Z-0.25 I-0.5302 J-0.5304
N1590 G0 Z0.1
N1600 G0 M5 M9
N1610 (Inch)
N1620 (Inch)
(2D contouring2)
N1630 M998
N1640 T6 G43 H6 M6
(.25" BN EM)
N1650 S4500 M3
N1660 G0
N1670 X-1.0861 Y-1.1695 Z0.1
N1680 M0
N1690 G1 Z-0.0278 F2
N1700 X-1.0971 Y-1.186 F40
N1710 G2 X-1.1083 Y-1.2025 Z-0.0278 I-1.7632 J1.186
N1720 X-0.2068 Y-1.3622 Z-0.0278 I0.2246 J-1.3565
N1730 X0.2068 Y-1.3622 Z-0.0278 I0.2068 J-0.3128
N1740 X1.1083 Y-1.2025 Z-0.0278 I0.6769 J-1.1968
N1750 X1.1083 Y1.2025 Z-0.0278 I1.752 J1.2025
N1760 X0.2068 Y1.3622 Z-0.0278 I-0.2246 J1.3566
N1770 X-0.2068 Y1.3622 Z-0.0278 I-0.2068 J0.3128
N1780 X-1.1083 Y1.2025 Z-0.0278 I-0.6769 J1.1968
N1790 X-1.0753 Y-1.1529 Z-0.0278 I-1.752 J-1.2025
N1800 G1 X-1.086 Y-1.1695
N1810 X-1.0861
N1820 Z-0.0556 F2
N1830 X-1.0971 Y-1.186 F40
N1840 G2 X-1.1083 Y-1.2025 Z-0.0556 I-1.7632 J1.186
N1850 X-0.2068 Y-1.3622 Z-0.0556 I0.2246 J-1.3565
N1860 X0.2068 Y-1.3622 Z-0.0556 I0.2068 J-0.3128
N1870 X1.1083 Y-1.2025 Z-0.0556 I0.6769 J-1.1968
N1880 X1.1083 Y1.2025 Z-0.0556 I1.752 J1.2025
N1890 X0.2068 Y1.3622 Z-0.0556 I-0.2246 J1.3566
N1900 X-0.2068 Y1.3622 Z-0.0556 I-0.2068 J0.3128
N1910 X-1.1083 Y1.2025 Z-0.0556 I-0.6769 J1.1968
N1920 X-1.0753 Y-1.1529 Z-0.0556 I-1.752 J-1.2025
N1930 G1 X-1.086 Y-1.1695
N1940 X-1.0861
N1950 Z-0.0833 F2
N1960 X-1.0971 Y-1.186 F40
N1970 G2 X-1.1083 Y-1.2025 Z-0.0833 I-1.7632 J1.186
N1980 X-0.2068 Y-1.3622 Z-0.0833 I0.2246 J-1.3565
N1990 X0.2068 Y-1.3622 Z-0.0833 I0.2068 J-0.3128
N2000 X1.1083 Y-1.2025 Z-0.0833 I0.6769 J-1.1968
N2010 X1.1083 Y1.2025 Z-0.0833 I1.752 J1.2025
N2020 X0.2068 Y1.3622 Z-0.0833 I-0.2246 J1.3566
N2030 X-0.2068 Y1.3622 Z-0.0833 I-0.2068 J0.3128
N2040 X-1.1083 Y1.2025 Z-0.0833 I-0.6769 J1.1968
N2050 X-1.0753 Y-1.1529 Z-0.0833 I-1.752 J-1.2025
N2060 G1 X-1.086 Y-1.1695
N2070 X-1.0861
N2080 Z-0.1111 F2
N2090 X-1.0971 Y-1.186 F40
N2100 G2 X-1.1083 Y-1.2025 Z-0.1111 I-1.7632 J1.186
N2110 X-0.2068 Y-1.3622 Z-0.1111 I0.2246 J-1.3565
N2120 X0.2068 Y-1.3622 Z-0.1111 I0.2068 J-0.3128
N2130 X1.1083 Y-1.2025 Z-0.1111 I0.6769 J-1.1968
N2140 X1.1083 Y1.2025 Z-0.1111 I1.752 J1.2025
N2150 X0.2068 Y1.3622 Z-0.1111 I-0.2246 J1.3566
N2160 X-0.2068 Y1.3622 Z-0.1111 I-0.2068 J0.3128
N2170 X-1.1083 Y1.2025 Z-0.1111 I-0.6769 J1.1968
N2180 X-1.0753 Y-1.1529 Z-0.1111 I-1.752 J-1.2025
N2190 G1 X-1.086 Y-1.1695
N2200 X-1.0861
N2210 Z-0.1389 F2
N2220 X-1.0971 Y-1.186 F40
N2230 G2 X-1.1083 Y-1.2025 Z-0.1389 I-1.7632 J1.186
N2240 X-0.2068 Y-1.3622 Z-0.1389 I0.2246 J-1.3565
N2250 X0.2068 Y-1.3622 Z-0.1389 I0.2068 J-0.3128
N2260 X1.1083 Y-1.2025 Z-0.1389 I0.6769 J-1.1968
N2270 X1.1083 Y1.2025 Z-0.1389 I1.752 J1.2025
N2280 X0.2068 Y1.3622 Z-0.1389 I-0.2246 J1.3566
N2290 X-0.2068 Y1.3622 Z-0.1389 I-0.2068 J0.3128
N2300 X-1.1083 Y1.2025 Z-0.1389 I-0.6769 J1.1968
N2310 X-1.0753 Y-1.1529 Z-0.1389 I-1.752 J-1.2025
N2320 G1 X-1.086 Y-1.1695
N2330 X-1.0861
N2340 Z-0.1667 F2
N2350 X-1.0971 Y-1.186 F40
N2360 G2 X-1.1083 Y-1.2025 Z-0.1667 I-1.7632 J1.186
N2370 X-0.2068 Y-1.3622 Z-0.1667 I0.2246 J-1.3565
N2380 X0.2068 Y-1.3622 Z-0.1667 I0.2068 J-0.3128
N2390 X1.1083 Y-1.2025 Z-0.1667 I0.6769 J-1.1968
N2400 X1.1083 Y1.2025 Z-0.1667 I1.752 J1.2025
N2410 X0.2068 Y1.3622 Z-0.1667 I-0.2246 J1.3566
N2420 X-0.2068 Y1.3622 Z-0.1667 I-0.2068 J0.3128
N2430 X-1.1083 Y1.2025 Z-0.1667 I-0.6769 J1.1968
N2440 X-1.0753 Y-1.1529 Z-0.1667 I-1.752 J-1.2025
N2450 G1 X-1.086 Y-1.1695
N2460 X-1.0861
N2470 Z-0.1945 F2
N2480 X-1.0971 Y-1.186 F40
N2490 G2 X-1.1083 Y-1.2025 Z-0.1945 I-1.7632 J1.186
N2500 X-0.2068 Y-1.3622 Z-0.1945 I0.2246 J-1.3565
N2510 X0.2068 Y-1.3622 Z-0.1945 I0.2068 J-0.3128
N2520 X1.1083 Y-1.2025 Z-0.1945 I0.6769 J-1.1968
N2530 X1.1083 Y1.2025 Z-0.1945 I1.752 J1.2025
N2540 X0.2068 Y1.3622 Z-0.1945 I-0.2246 J1.3566
N2550 X-0.2068 Y1.3622 Z-0.1945 I-0.2068 J0.3128
N2560 X-1.1083 Y1.2025 Z-0.1945 I-0.6769 J1.1968
N2570 X-1.0753 Y-1.1529 Z-0.1945 I-1.752 J-1.2025
N2580 G1 X-1.086 Y-1.1695
N2590 X-1.0861
N2600 Z-0.2222 F2
N2610 X-1.0971 Y-1.186 F40
N2620 G2 X-1.1083 Y-1.2025 Z-0.2222 I-1.7632 J1.186
N2630 X-0.2068 Y-1.3622 Z-0.2222 I0.2246 J-1.3565
N2640 X0.2068 Y-1.3622 Z-0.2222 I0.2068 J-0.3128
N2650 X1.1083 Y-1.2025 Z-0.2222 I0.6769 J-1.1968
N2660 X1.1083 Y1.2025 Z-0.2222 I1.752 J1.2025
N2670 X0.2068 Y1.3622 Z-0.2222 I-0.2246 J1.3566
N2680 X-0.2068 Y1.3622 Z-0.2222 I-0.2068 J0.3128
N2690 X-1.1083 Y1.2025 Z-0.2222 I-0.6769 J1.1968
N2700 X-1.0753 Y-1.1529 Z-0.2222 I-1.752 J-1.2025
N2710 G1 X-1.086 Y-1.1695
N2720 X-1.0861
N2730 Z-0.25 F2
N2740 X-1.0971 Y-1.186 F40
N2750 G2 X-1.1083 Y-1.2025 Z-0.25 I-1.7632 J1.186
N2760 X-0.2068 Y-1.3622 Z-0.25 I0.2246 J-1.3565
N2770 X0.2068 Y-1.3622 Z-0.25 I0.2068 J-0.3128
N2780 X1.1083 Y-1.2025 Z-0.25 I0.6769 J-1.1968
N2790 X1.1083 Y1.2025 Z-0.25 I1.752 J1.2025
N2800 X0.2068 Y1.3622 Z-0.25 I-0.2246 J1.3566
N2810 X-0.2068 Y1.3622 Z-0.25 I-0.2068 J0.3128
N2820 X-1.1083 Y1.2025 Z-0.25 I-0.6769 J1.1968
N2830 X-1.0753 Y-1.1529 Z-0.25 I-1.752 J-1.2025
N2840 G1 X-1.086 Y-1.1695
N2850 X-1.0861
N2860 G0 Z0.1
N2870 G0 M5 M9
N2880 (Inch)
N2890 (Inch)
(Hole machining)
N2900 M998
N2910 T12 G43 H12 M6
(.108" center drill)
N2920 M3
N2930 G0
N2940 X-1.7675 Y-1.675 Z0.3937
N2950 G0
N2960 M8
N2970 G98 G85 Z-0.06 R0.039 F2.
N2980 G0 X0. M0
N2990 G85 Z-0.06 R0.039 F2.
N3000 G0 X1.7675
N3010 G85 Z-0.06 R0.039 F2.
N3020 G0 Y1.675
N3030 G85 Z-0.06 R0.039 F2.
N3040 G0 X0.
N3050 G85 Z-0.06 R0.039 F2.
N3060 G0 X-1.7675
N3070 G85 Z-0.06 R0.039 F2.
N3080 G80
N3090 G0 M5 M9
N3100 (Inch)
N3110 (Inch)
(2D contouring4)
N3120 M998
N3130 T18 G43 H18 M6
(.25" chamfering 90 degree)
N3140 S5000 M3
N3150 G0 G94
N3160 X-0.8914 Y-1.639 Z0.1
N3170 M0
N3180 G1 Z-0.095 F2
N3190 G3 X-1.2393 Y-1.7105 Z-0.1 I0.0077 J-0.92 F20
N3200 X-1.5342 Y-1.9084 Z-0.1 I0.3556 J-0.8485
N3210 G2 X-1.9478 Y-1.3986 Z-0.1 I-0.2333 J0.2334
N3220 G3 X-1.9478 Y1.3986 Z-0.1 I-0.9125 J1.3986
N3230 G2 X-1.5342 Y1.9084 Z-0.1 I0.1803 J0.2764
N3240 G3 X-0.2333 Y1.9084 Z-0.1 I0.6505 J0.6506
N3250 G2 X0.2333 Y1.9084 Z-0.1 I0.2333 J-0.2334
N3260 G3 X1.5342 Y1.9084 Z-0.1 I0.6505 J0.6506
N3270 G2 X1.9478 Y1.3986 Z-0.1 I0.2333 J-0.2334
N3280 G3 X1.9478 Y-1.3986 Z-0.1 I0.9126 J-1.3986
N3290 G2 X1.5342 Y-1.9084 Z-0.1 I-0.1803 J-0.2764
N3300 G3 X0.2333 Y-1.9084 Z-0.1 I-0.6504 J-0.6506
N3310 G2 X-0.2333 Y-1.9084 Z-0.1 I-0.2333 J0.2334
N3320 G3 X-1.2393 Y-1.7105 Z-0.1 I-0.6504 J-0.6506
N3330 G0 Z0.1
N3340 X-0.952 Y-0.8273
N3350 G1 Z-0.095 F2
N3360 G2 X-1.0403 Y-1.0068 Z-0.1 I-1.9084 J0.8273 F20
N3370 X-1.1454 Y-1.177 Z-0.1 I-1.8201 J1.0068
N3380 G3 X-1.101 Y-1.2469 Z-0.1 I0.0371 J-0.0255
N3390 G2 X-0.229 Y-1.4014 Z-0.1 I0.2172 J-1.3121
N3400 G3 X-0.182 Y-1.3997 Z-0.1 I0.0222 J0.0392
N3410 G2 X0.182 Y-1.3997 Z-0.1 I0.182 J-0.2753
N3420 G3 X0.229 Y-1.4014 Z-0.1 I0.0248 J0.0375
N3430 G2 X1.101 Y-1.2469 Z-0.1 I0.6548 J-1.1577
N3440 G3 X1.1454 Y-1.177 Z-0.1 I0.0074 J0.0444
N3450 G2 X1.1454 Y1.177 Z-0.1 I1.7149 J1.177
N3460 G3 X1.101 Y1.2469 Z-0.1 I-0.0371 J0.0255
N3470 G2 X0.229 Y1.4014 Z-0.1 I-0.2172 J1.3121
N3480 G3 X0.182 Y1.3997 Z-0.1 I-0.0221 J-0.0392
N3490 G2 X-0.182 Y1.3997 Z-0.1 I-0.182 J0.2753
N3500 G3 X-0.229 Y1.4014 Z-0.1 I-0.0248 J-0.0375
N3510 G2 X-1.101 Y1.2469 Z-0.1 I-0.6548 J1.1577
N3520 G3 X-1.1454 Y1.177 Z-0.1 I-0.0073 J-0.0444
N3530 G2 X-1.0403 Y-1.0068 Z-0.1 I-1.7149 J-1.177
N3540 G0 Z0.1
N3550 G0 M5 M9
N3560 (Inch)
N3570 M998
N3580 M30
Carlos A. Diaz
TPR Motorsports
803.334.8674
TPR
post Apr 17 2013, 04:10 AM
i also noticed it gets stuck just after the tool change and just before the M0, which requires me to hit cycle start again to get it going.
thanks for the help
Carlos A. Diaz
TPR Motorsports
803.334.8674
TPR
post Apr 17 2013, 05:36 AM
As far as the tool offset issue, I checked to make sure all my tool correction factors were matching the the tool numbers n they are per eric Anderson's tormach video.
Thank u
Carlos A. Diaz
TPR Motorsports
803.334.8674
TPR
post Apr 17 2013, 01:17 PM
i hit the link above uninstalled sprutcam then hit the link again and reinstalled it, i am now able to edit my library with out getting that error window, i was able to edit 2 of the 4 missing tools and now they show up, i still have 2 tools that no matter how much i edit them they do not show up. only way to access the 2 missing tool is to go to tormach machine, then work with tool library and i can see them there, i just cant see them during the machining operation menu.
i havent tried to run the new program yet, it was 1:30am when i got done reinstalling everything....
thank you
Carlos A. Diaz
TPR Motorsports
803.334.8674
TPR
post Apr 18 2013, 12:43 AM
all my library editing issues seem to be gone now which is great, BUT the new issue with the tool offset i still need to resolve.
is there a setting that specifies to aknolwdge the different tool offsets? it almost seems like it using the tool length from the first tool i use to zero.
please help
Carlos A. Diaz
TPR Motorsports
803.334.8674
TPR
post Apr 19 2013, 04:50 AM
Problem solved, I had completely overlooked setting up my tool table in the controller, major newbie mistake, after all I am a newbie... Lol I had setup my tool library in sputcam but not my tool table. Worked great
Carlos A. Diaz
TPR Motorsports
803.334.8674
post Apr 20 2013, 03:13 PM
Post #16
QUOTE (TPR @ Apr 19 2013, 05:50 AM) *
Sorry for the delay in my reply, I've been unwell for a few days.
Thank you for the update. I'm pleased that you've successfully managed to solve your problem(s).
It sounds like you have set yourself quite a steep learning curve. It can sometimes seem like you are banging your head against the proverbial brick wall, especially when you are new to everything and don't know which way to turn!
Please keep us up to date with your progress.
bones288
post Apr 22 2014, 06:29 PM
Post #17
QUOTE (TPR @ Apr 18 2013, 09:50 PM) *
I was just about to ask you this! Very good learning curve. If you start messing around with CS offsets just remember to run every new toolpath at a feedrate of 10% until you're sure the machine, the tool, and your expectations are all on the same level. I've ploughed several tools into my workpieces at 100% bcs I was learning about altering my cs points.
Good luck.
post Sep 22 2014, 07:46 PM
Post #18
I'm having new issue, and its on both machines, I have not looked into if the admin issue is the cause. In SC8 if I took the stock library and wanted to save it, "save AS" when I do that and go back to the library that I just saved... it is completely empty!
Not sure what is going on :/
post Sep 23 2014, 05:43 PM
Post #19
I'm also having problems with the SC8 tool library. It now defaults to using the standard metric library that comes with SC8. I can load my custom library and see it in the list, but once that dialog box is closed the custom library is gone and only the default metric library is available.
post Sep 26 2014, 11:10 PM
Post #20
It seems that it really does not like to have custom folder location, I manually found the library directory and went back to original, but still having random issues with this, and I am being cautious by making a copy of the files that I modify or save to, as to not get them lost/replaced with blank completely.
Thats what I would advise, make copy/backup of the file you intend to either save over/replace
2 Pages V   1 2 >
Lo-Fi Version Time is now: 17th July 2019 - 04:22 AM
