> rest milling not cooperating, rest milling
neeboy
post Jun 14 2015, 09:09 PM
I am trying to machine a design using large and small bits. It's my understanding that a SC finishing toolpath should automatically carve away material left behind by a roughing toolpath. I have tried that, and I have tried using a specific "rest" milling operation, but the result is ALWAYS the same! angry.gif The finishing toolpath only carves away the diameter of the bit, even though the material needed to be removed is wide than that. I have tried everything I can think of, read the help/manual files, but the result is always exactly the same. Please see the attached file, it's pretty clear what I want to do. Thanks in advance for any help!
Attached File  rest_milling_question.stc ( 680.6K ) Number of downloads: 2
post Jun 15 2015, 05:44 AM
Hi Neeboy,
The SprutCAM finishing operations do not do rest machining based on remaining material by default, it is the roughing operations that do this. Generally speaking the roughing operations only machine the workpiece and because the workpiece for an operation is the 'Machining result' of the previous operation, this makes rest machining standard for the roughing operations.
The finish operations do not consider the workpiece by default, this must be selected under 'Trimming' if it is required.
I have altered your second operation (attached) to show this.
If you use the 'database' settings there are more options available for rest machining............these include 'Theoretical' rest milling which allows rest machining to be calculated without first doing any roughing.
I hope this helps?
Attached File  rest_milling_question_dp.stc ( 684.44K ) Number of downloads: 3
post Jun 15 2015, 03:19 PM
I have modified your project to show the use of a second waterline roughing operation (attached).
Attached File  rest_milling_question_dp1.stc ( 841.22K ) Number of downloads: 1
neeboy
post Jun 16 2015, 12:09 AM
Lo-Fi Version Time is now: 18th July 2019 - 12:26 AM
