> Only generate curves with G1
sandino
post Sep 26 2016, 01:48 AM
Newbie
Hi,
I want to create a postprocessor for Fanuc, the post processor must not create codes G2 and G3, the curves will be generated only with G1, is that possible?
Thank you
post Sep 28 2016, 01:11 PM
Hi Sandino,
Welcome to the SprutCAM user forum. The easiest way to achieve what you require is to deselect the 'Use arcs' option for the machine configuration being used.
I'm using a different PC to my usual one at the moment so cannot do a screengrab, in Machining mode left click the machine that you are using (e.g. 3-axis milling machine), then click the 'Machine setup' tab below, then select '+' next to arcs and you will see the 'use arcs' option.
You may find that this resets itself whenever you start a new project, if this does happen, the default setting can be changed by altering the SprutCAM machine configuration.
I hope this helps?
sandino
post Sep 30 2016, 04:05 AM
Newbie
Hi Dave,
Thank you very much
That was what I needed
sandino
Newbie
Hi Dave,
Thank you very much
Lo-Fi Version Time is now: 19th July 2019 - 04:43 PM
