> Drilling cycle issue with Tormach post
post Jan 19 2007, 08:59 AM
I've been asked to consolidate the fixes for the Tormach post processor that you've graciously provided on this forum. This includes the fixes that Yuri sent me for compatibility with NCTuner as well as the fixes for the helical path and multiple hole drilling issues that you provided others on this forum. I've done quite a bit of testing and these fixes do seem solid. However, I have uncovered another issue with the original post in my testing. If a toolpath for, say, a simple drilling operation is created for a workpiece whose top surface is above Z=0, then the G81 line that is created in the g-code does not contain the required Z depth. If the workpiece is transformed so that the top surface is at Z=0 then the line is properly generated. Do you see an easy edit to our post to correct this?
post Jan 19 2007, 05:28 PM
Terry, I'm very busy this weekend with DIY work that HAS to be done (so I've been told ;o).
So that I'm modding the correct post, e-mail me the one that you are using now and I'll take a look when I have a bit of time. It may be a simple fix, or it could be quite involved, it all depends on how the drilling routines have been handled in this post......
post Jan 21 2007, 05:02 AM
Hi Terry, I've just had a quick look at the postprocessor and I cannot spot any obvious problems at this stage.
Can you check to make sure that in the project you are using to test the drilling you have the 'Safe plane' higher than the 'Safe level / Distance' height as if it is lower this will give incorrect values.
If this is ok, can you please post up an example of what is going wrong.
post Jan 21 2007, 07:59 AM
I've emailed a project which isolates the problem. I believe the safe plane is properly located above the safe distance/level.
post Jan 21 2007, 09:55 AM
Terry, it was your description of the fault which was confusing. The problem only actually occurs when the 'zmin' for a hole is set to 0, for all other instances it works fine.
The fault is caused because the initial value of the register that outputs the Z depth of a hole (zcycle) is 0, and because the value of the register does not change when the cycle is read, the register does not respond.
To solve this problem we need to give the register an initial value which is not 0, and in fact we need to give it a value that it is never likely to get passed by SprutCAM.
All I did to achieve this was to add this line to the PartNo program:
Zcycle = MaxReal; Zcycle@ = ZCycle
This gives the zcycle variable an initial value of 99999.999.
post Jan 21 2007, 04:16 PM
Thanks much. That change to the post seems to have fixed it!!
best regards
Lo-Fi Version Time is now: 16th July 2019 - 12:50 PM
