> Export simulation result for subsequent machining?
Mike Henry
post Nov 2 2012, 11:54 PM
Is there a way to save the result of a simulation from one project and importing it into another for additional machining?
I have a part that needs to be machined on both sides but I'd like to do the first side on a batch of several parts and do the otherside as a second batch. I see that the simulation results can be saved as an STL file, but with that format the model features that have not been machined yet are lost during the import. That makes it difficult to use the model features in the job assignments for the operations on the second batch.
Mike
post Nov 3 2012, 08:45 AM
Hi Mike, once you have simulated a SprutCAM project you can export the 'Simulation result'. You can adjust the 'quality' of the exported stl model in Simulation mode by altering the slider for 'Tool/Model tolerance' (see attached image: Tolerance.png).
You can also export the original 'Model' as an stl file. To do this, in Model mode select the complete model and right click on it, then select 'Save as...' (see attached image: save.png). You can also alter the tolerance of this model by altering the 'Tolerance digits' value found under 'System setup' - 'measurement units', see attached image: digits.png.
I hope this helps.
Mike Henry
post Nov 11 2012, 06:28 PM
Thanks Dave. In order to accomplish what I'd like to do, it appears that I'd need to somehow import the STL model and superimpose the exported simulation of machining one end of the part over the model to create the "stock" to be removed. If that is correct, it is not clear to me how that can be done - can you offer any suggestions?
Does SC 8 offer any enhancements that would help with this sort of thing? I've ordered the upgrade and it should be here next week.
Mike
QUOTE (Sprut_UK @ Nov 3 2012, 08:45 AM) *
I hope this helps.
post Nov 12 2012, 07:42 AM
Hi Mike, in 'Model' mode, select the 'Workpiece' folder, then click 'Import' and select the required *.stl model. The initial X/Y/Z datum for this will be the same as that used in the previous SprutCAM project that the *.stl model was exported from.
The only change to the Workpiece functionality in SC8 is that you can now add stock to a model to effectively create a 'casting' model.
You can see some info on the new features in SC8 here: http://www.sprut.ru/files/SprutCAM8/Whats_...SprutCAM_8.html
Mike Henry
post Nov 18 2012, 12:12 AM
QUOTE (Sprut_UK @ Nov 12 2012, 07:42 AM) *
Thanks Dave - it sounds like that would work without too much trouble. SC8 arrived yesterday and I hope to give it a spin tomorrow.
Mike
Lo-Fi Version Time is now: 19th July 2019 - 08:08 AM
